Sloppy drive train on a B
Steve
11-26-1999 19:30:50
While changing brake bands on my B, I noticed I could move the brake drum about 1 1/2" before taking up the slack either to the wheel or rear. Is this common? The left side has very little play at all. There was no indication of problems before the repair. The drum is tight on the shaft.
Dick L in NW Ohio
11-30-1999 07:39:14
 Re: Sloppy drive train on a B in reply to Steve, 11-26-1999 19:30:50
Jack up that side and see if the play is there when you move the tire back and forth. If not the retainer set screw has worked out and most likley the keyway is worn out also. Look through the hole under the axle housing with a light and you can see if the screw is gone. You will have to turn the tire untill the hole or stud on the break drum flang is down. I used a 3/8" grade 8 bolt on my B, but I didn't have the slop. If the stud is gone you might have use a pry bar on the top side to center the break drum before tightening the stud. If the slop is that bad after jacking up the tractor that is a hole different problem. Hope this helps, please get back to us with what ever you find.
