Question on...Model B mag...4B Or..?????
loveshisallis
05-09-2008 06:38:42
Hello;
I had a problem wiht my FM J mag so swapped it to a FM 4B that i had on the shelf. Thing is it wants to start, but acts like it is too advanced.
NOTE: Same rotation, same 30 degree lag angle. So....will this mag work on the model B engine, or am I all wet?
ppreciate it.
steve(ill)
05-10-2008 19:57:57
 Re: Question on...Model B mag...4B Or..????? in reply to loveshisallis, 05-09-2008 06:38:42
read this
http://www.worldpath.net/~thompson/acb/magtiming/magtiming.htm
El Toro
05-09-2008 14:31:51
Did you note where the rotor was pointing before removing the mag? If you didn't you need to bring No1 piston near the radiator to TDC on the compression stroke. Then see where your rotor is pointing. It should be at the No1 plug tower on your cap. Make sure your plug wires are in the correct firing order on the cap. 1-2-4-3
Hal
PS: If the rotor is off you will need to pull the mag and rotate the rotor so it points to the No1 plug tower on the cap. Then reinstall the mag.
