Replace water pump Allis D-19 Gas
Claude J
05-07-2008 04:30:39
I need to replace my water pump as it leaks out thru seal and down the fan blade. Does anyone have any tips to give me to save some headaches. I plan to remove the raditor. Also what do you recomend to seal up the gasket? Just use the bare gasket or also use a sealant?????
Donald Gay
05-08-2008 10:33:17
 Re: Replace water pump Allis D-19 Gas in reply to Claude J, 05-07-2008 04:30:39
I always use a little RTV sealant on all gaskets. It helps a whole lot more than it hurts.
Wisconsin Cowman
05-08-2008 07:15:01
I usually but a little flange sealant on my gaskets.
Jerry Coulter
05-07-2008 04:46:32
Shop manual says to remove radiator. Nothing about sealant on the new gasket, but I certainly would use it to keep antifreeze from seeping through. "Tighten pump mounting capscrews 18 to 21 ft. lbs. torque."
