D17 hitch won't lower
Ray
05-03-2008 17:26:46
I have a D17 series 4 that the snap coupler hitch won't go down.The hitch lever is free,and when pulled back loads the hydraulic system but when pulled foreward the hitch stays up.I was told the inside valve by the fender is sticking,but it is free along with the finger that moves it.Any ideas? Thanks.
roundman
05-11-2008 11:47:06
 Re: D17 hitch won't lower in reply to Ray, 05-03-2008 17:26:46
You could try to spray Liquid Wrench or WD-40 on the linkage under the hydraulics by the fender, this kept everything free and working,if the tractor is not used alot
Texas Denny
05-05-2008 10:01:57
I would suggest checking the linkage. If something got loose, it could leave the valve in the hold position. I haven't had this experience on a D series but it did happen on a WD.
Also, make sure the oil level is right. With low oil, air can be introduced into the system and funny things can happen - like raising when not asked to and not coming down when asked to. If it is air, a large load should bring the arms down. Going up and down a few times should clear the air.
roundman
05-04-2008 09:14:42
make sure the traction booster & position control levers are in the forward position
Ray
05-04-2008 17:31:10
 Re: D17 hitch won't lower in reply to roundman, 05-04-2008 09:14:42
Tried all that stuff,still nothing.
