wd 45 main
reichstall
05-03-2008 12:06:08
ok what a pain installing std bearing on unground shaft everything mics out ok but alas when you try to plasticgauge the main with the shim install i get .004 cant turn shaft with out shim i can get .002 but alas still cant turn shaft what am i doing wrong here.i know we want to shoot for the .002 but if i understand i should be able to turn shaft am i wrong thanks all
Jay Snyder
05-03-2008 15:38:07
 Re: wd 45 main in reply to reichstall, 05-03-2008 12:06:08
All of the journels mic out right.When I did mine I had all but the front on was good and the samething had happened I got a new crank and it was fine but you can have it turned and put different bearings in it and you would be fine. Hope that this helps and wish you luck.
