Question on zerks in three point hitch, D-17
loveshisallis
05-01-2008 15:25:58
I have what I believe is an original allis three point hitch conversion on my D-17. On the arms two of the zerks are missing, so put treid to put a baling wire in it to check if it was clear and it wouldn';t go. So, I took a 7/32 drill and took out enough so that grease now gets through. ONly had the 1/4" threaded zerks, and put them in.
BUT, i noticed that the orginal equipment usees the pressed in zerks.
So, can anyone tell me WHERE I can get them, and HOW they are installed?
Thanks
gatz
05-01-2008 19:38:48
 Re: Question on zerks in three point hitch, D-17 in reply to loveshisallis, 05-01-2008 15:25:58
look on page 2134 of McMaster-Carr for drive-in zerk fittings...or check with an automotive parts place.
if you've got a 7/32" hole now (probably a little larger), you should use a 1/4" reamer for sizing the hole so that the zerk will be a press fit.
Note that it won't be easy to remove if ever needed....they are meant to stay.
On the other hand; if the hole is too big, when you grease it, the zerk will just be pushed back out.
