B C CA G WD WD45 Battery Insulators
Scott(GA)
04-30-2008 15:24:01
I've got a few Dealer Parts Catalogs for various AC tractors. According to these Catalogs, the Insulator, battery box cover (Part # 211435) & the Insulator, battery box (Part # 210908) are common to the B, C, CA, G, WD & WD45 tractors. (Perhaps others - these are the ones I had that matched.)
I have a G that I'm working on. I've never even seen a complete original metal Battery Box - let alone the insulators. The B IB C Parts catalog notes that these Insulators were made of wood. Sounds like the insulators could be reproduced with some common woodshop tools - if the dimensions of these insulators were known.
Question: Does anyone have knowledge of the dimensions of the top & bottom battery insulators? Even better, does anyone have the actual insulators? I'd be interested in the type of wood as well - plywood or whatever.
Thanks!
Scott
Scott(GA)
05-03-2008 20:49:44
 Re: B C CA G WD WD45 Battery Insulators in reply to Bill in MA, 04-30-2008 15:24:01
JMS/.MN said: (quoted from post at 02:45:27 05/03/08) They were made out of masonite. Plywood was invented later. Circa 1950 or so.
It appears that plywood was invented prior to masonite...
Link
Link
Below is where the "wood" reference came from (part # 3). I think they actually mean wood since there is also reference to a spacer (part # 4) on the IB that is made of wood.
Best regards,
Scott
third party image
third party image
JMS/.MN
05-02-2008 18:45:27
 Re: B C CA G WD WD45 Battery Insulators in reply to Scott(GA), 04-30-2008 15:24:01
Scott(GA)
05-01-2008 18:54:43
 Re: B C CA G WD WD45 Battery Insulators in reply to Mark In WV, 04-30-2008 15:24:01
Charles,
Thanks! Sounds like masonite.
Best regards,
Scott
Charles Bradshaw said: (quoted from post at 21:16:40 05/01/08) Scott i worked in the parts dept for a A/C dealer for 13 years and sold many of the insulators you are talking about. I am sorry to say i do not know the measurements but the material was a dark brown type pressed paper some what like the material peg board is made of less all the holes. hope this will help you.
Charles Bradshaw
05-01-2008 13:16:40
Uncle Ernie
04-30-2008 19:41:41
Made mine out of the sidewall of a tire. Tough stuff!
chalmersbob
04-30-2008 19:10:46
just measure the battery and make the insulator 1/2" smaller. 1/8" masonite or formica will work fine. I have seen some solid and some with holes at the fill caps. Bob
T.J.-N.J.
04-30-2008 16:58:01
When our 42 C was delivered in 76 the dealer had put a new battery box on it and it had a masonite insulator in it. T.J.
Cman
04-30-2008 16:31:14
Does anyone have the measurements for making a battery box, with the cover and the insulator.
Thanks..... ..... ....
Working on a 1949 AC B..... ...
