Need help with zerks....
loveshisallis
04-30-2008 07:51:29
I got a couple of 1/4 " zerks missing from the back hitch on my D-17. When I tried to thread new ones in they stripped out. When they were in however, i tried to grease, and pumped, then they popped out.
Sooooo oo, hows about the best way to fix this and get it right?
Thanks a bunch
LEONMI
05-02-2008 04:57:46
 Re: Need help with zerks.... in reply to loveshisallis, 04-30-2008 07:51:29
THE ZERKS MAY BE OF THE TAP IN TYPE.LOOKS LIKE THEY ARE THREADED,BUT THEY ARE NOT. I DON'T KNOW IF THIS APPLIES TO AC TRACTORS.
chuck bergstrom
05-01-2008 09:34:17
If all else fails go to a good implement or auto
parts store where they have a good selection of
zerks. You can get"drive in styles" in several
sizes or otherwise you may have to retap. Chuck
5B Ranch
05-01-2008 09:14:55
Stupid question of the day - what's a zerk?
Dr.Dan
05-01-2008 21:05:04
 Re: Need help with zerks.... in reply to 5B Ranch, 05-01-2008 09:14:55
a grease fitting...no question is dumb...this is how we learn.
VBR, Dan
5B Ranch
05-02-2008 07:42:05
 Re: Need help with zerks.... in reply to Dr.Dan, 05-01-2008 21:05:04
Wow - I have never heard that term. I always just called them nipples. Learn something new every day.
Thanks!
garytomaszewski
05-01-2008 07:10:59
Before you replace the zerk CLEAN the hole!!!, use a small drill to get the dirt out and then squirt some of your favorite penetrant in to loosen what you couldn't dig out, then pump it FULL of grease.
Kentb of SWMO
05-01-2008 06:47:01
The 1/4" zerks a 1/4" x 28 thread. you could HELI-COIL the hole or enlarge to 1/8" pipe.
Kent
chalmersbob
04-30-2008 19:12:35
there are several sizes of zerks, with different threads. try another size. Bob
elijah
04-30-2008 07:59:59
I have went oversize and also tack welded standard size in stripped hole. Both worked well, you could also heli-coil the holes which would probably be the most proper way. Best of luck.
