b rim
peetzallis
04-28-2008 11:48:51
ok, after a long day of plowing and disking with my allis model b, i noticed that the rim spun and knocked off my valve stem. also noticed that the rim is rusted out, time to be replaced. my question is do i replace with same style rim or is there a different one i can use. tire size is 11.2-24 on a hump style rim that has 4 bolts. i thought i remember reading on here somewhere that a farmall a rim will work and have loops for the bolts to secure it to the hub instead of the hump style. any input would be appreciated.
peetzallis
04-30-2008 06:05:32
 Re: b rim in reply to peetzallis, 04-28-2008 11:48:51
thanks for the replies. i am going with a farmall b rim like you stated. they are readily available for about 1/3 the price.
chalmersbob
04-29-2008 19:19:07
you won't have that problem if the rim is installed properly. One wheel mount ,bolted type, not cam, gets mounted between the 2 blocks on the rim. This keeps it from spinning. Bob
peetzallis
04-30-2008 06:11:00
 Re: b rim in reply to chalmersbob, 04-29-2008 19:19:07
thanks for the info chalmersbob. what actually happened is it rusted around one the blocks on the rim, which broke off allowing the rim to spin. it was installed properly until that happened.
Clay in MI
04-28-2008 17:47:20
Been there, done that. One of my B's now has the 4 loop rims from a Massey Pony. Perfect fit and no more rim spin. And they're cheaper.
old
04-28-2008 13:17:35
4 lope rims made for the farmall B will bolt right on and stop that problem
