Allis-Chalmers HD5 Loader broken track sprocket shaft
john in virgini
04-27-2008 15:27:22
I broke the left "track sprocket shaft between the spline for the sprocket and the intermediate bearing assembly. Questions: How can I retreive the inner part of the shaft which has the 51 tooth gear attached to it? Do I have to go up through the bottom final drive compartment cover to release the 51 tooth gear from the shaft?
Because of the location of the break, I was able to wiggle the entire sprocket and outer bearing bracket out between the final drive housing and track frame. I am certain the reassembling will not be that easy or simple because of the length of the new shaft. SUGGESTION?!?
hector gemme
04-27-2008 15:54:28
 Re: Allis-Chalmers HD5 Loader broken track sprocket shaft in reply to john in virginia, 04-27-2008 15:27:22
You need to removed the bottom cover final drive compartment and removed the lock gear retaining for removing the shaft to the gear but you need to take off the sprocket and the retaining cage before pull out the shaft and am still have those parts.
HECTOR
