Question on magneto and plugs?
loveshisallis
04-27-2008 13:36:13
Hello ;
Appreciate all the good help I get from you good folks!
My question is with a magneto, can you run a resistor plug or not? I am running solid core wires on the B. I am running the champion J-* plugs (NON-resistor) now, and think that it ran better with the AC R 44.s
DARDAN
04-29-2008 00:18:26
 Re: Question on magneto and plugs? in reply to loveshisallis, 04-27-2008 13:36:13
I was told by an old, seasoned Fairbanks mag rebuilder that to run resistsnce wires or plugs will overload the mag coil and damage it.
Military and aircrft use external shielding on mag ignitions. ie metal braid on outside of wires and spark plugs with a steel outer shell, and threaded metal connectors. And a metal cover over the cap.
John T
04-28-2008 04:03:52
Its especially important when using a limited energy ignition such as a Magneto NOT to use resistive suppressor plug wires or resistor plugs. Unless youre worried about radio interference you want to discharge all the mag coils limited stored energy across the spark plug gap and NOT waste energy in the form of heat loss in resistive wires or plugs. Theres no "free lunch" (cant create or destroy energy, only change its form) and the energy stored in the mags coil during its conduction is best for initiatign the combustion process via a higher energy plug gap discharge versus heat in a resistor.
Low energy mags or old technology coil ignitions (as old tractors use) are NOT the same as later model high energy high voltage solid state ignition systems that might use some degree of ballast (resistive wires or plugs) in the secondary for radio interference suppression or other purposes.
USE WIRE CORE WIRES AND NON RESISTOR PLUGS IN OLD TRACTOR MAGNETO IGNITIONS IS MY ADVICE
John T Retired Electrical Engineer
Kentb of SWMO
04-27-2008 19:51:48
Why No resistor plug? Most small engine are magneto and they run resistor plugs from the factory to prevent RFI. You need to limit RFI as this might keep a PREDATOR drone from zapping a raghead. If it were mine I would run RJ-19LM plugs in it.
Kent
steve(ill)
04-27-2008 18:42:12
dont use the resistor plugs. with a mag, you should have copper core wires and Autolite #295. the J-8 works for some people, but many have troubles.
Bob Bancroft
04-27-2008 15:48:38
Allis engines and Champion plugs never got along. Best thing I find now is Autolite#306.
Dave Stanford
04-27-2008 15:15:36
Seems OK to me-picture the actions taking place-the magneto's magnets are whirlng around inducing a flow of electrons down the cable to either a plug with no resistor or one with-the only difference would be the amount of resistance-and the whole point of high voltage is to surmount a high resistance and jam a spark across a .035 gap; ergo it shouldn't matter if a few hundred ohms are added. I had trouble with a Triumph motorcycle. It turned out that my wires had 100,000 ohms and were spec'ed at 35,000-thus it wouldn't run well some times. You are saying it runs better so go with it!
