D19 Roosa mater injection pump leaking
VC/TX
04-26-2008 13:34:17
third party image
any body know how remove the throttle & kill lever shaft on the roosa mater injection pump. I would like to replace the o ring on mine, it"s starting to leak a little diesel around the shaft on the pump on my D19.
need to know how to remove the shaft,any help would be appreciated
Bob
04-27-2008 18:45:21
 Re: D19 Roosa mater injection pump leaking in reply to VC/TX, 04-26-2008 13:34:17
CLEAN the darned thing up. Remove the pump cover.
Remove a goofy little clip, allowing the throttle shaft to be withdrawn from the IP.
Replace the "O" rings on the throttle shaft, slather them up with a little Vaseline, and put the shaft and clip back in place, while keeping all the associated parts in place.
Put the pump cover back on.
(One of those things that's a lot easier to DO than to write about!)
