1944 Allis Chalmers model B tractor battery problem
Scott Thompson
04-25-2008 15:51:40
1944 Allis Chalmers model B tractor has a brand new battery but it runs down after only a half mile drive. No previous problems, may be shorted out somewhere. Generator gets hot, could that be why its not charging the battery? The voltage regulator is new. The amp meter shows charging.
Can anyone provide some suggestions/solutions?
CTucker NWIL
04-25-2008 18:48:29
 Re: 1944 Allis Chalmers model B tractor battery problem in reply to Scott Thompson, 04-25-2008 15:51:40
Sounds like you might need to polarize you genny. Did you just replace the batter ? Did you switch cables around? If it's original set up it should be pos ground and have a cut out relay,no voltage regulator.
