Firing order
Johnny Rowland
04-24-2008 21:11:22
I have a 1952 Allis Chalmers CA 4 cyl. Gas I know the firing order is 1-2-4-3,Are the cyls. numbered from the front of the tractor to the back??I need to know the cyl. #'s on the distributor cap,I'm trying to get the wires in the right order..
Jack a
04-25-2008 04:03:25
 Re: Firing order in reply to Johnny Rowland, 04-24-2008 21:11:22
1,2,4,3 is right starting from the front working back. I think #1 on the cap is toward the front closest to the block but that can change if the distributor has been removed and replaced a tooth or two off. Best to take the plug out of #1 and with switch off and the coil wire removed turn the engine over with the crank and place your thumb over the spark plug hole. When you feel compression then look to see what post the rotor under the cap is coming to next. That's the #1 post.
old
04-24-2008 22:18:44
From the radiator back they are 1,2,3,4. Get #1 at TDC and pull off the distributor cap and look where the rotor points and then go from there. Also watch which way it turns so you know which way to put the wires on. Most of the time a picture will not help because the distributor could have been put on different then what it was when new so where #1 is can change
Johnny Rowland
04-25-2008 18:41:06
 Re: Firing order in reply to old, 04-24-2008 22:18:44
Thanks Guys,Now I"ll see if I can fix it..
El Toro
04-27-2008 04:36:27
 Re: Firing order in reply to Johnny Rowland, 04-25-2008 18:41:06
Your plug wires probably need to be in this firing
order on the cap. Hal
PS: Its better to bring No1 piston to TDC on the compression stroke and note which way the rotor turns. I think its CCW. 1-3
2-4
