WD 45 Oil Pan
Slowfolk
04-24-2008 08:44:58
Recently has the oil pan off of a WD 45 and after replacing I have an oil leak at the rear of the pan. I must have installed the cork seal that seals around the bearing block both at the rear and front in-correctly. I did shorten them some as I thought they were too long. Any good suggestions on how to get them in place.
Thanks
Jack a
04-25-2008 04:38:14
 Re: WD 45 Oil Pan in reply to Slowfolk, 04-24-2008 08:44:58
I did that too years ago on my Dad's D17. My first overhaul. I didn't want to redo it (back in the 80's we were short of money and Dad didn't want to spend any more and it was his main tractor and on a dairy farm it was a must to get it going) so I took a can of parts cleaner spray and sprayed and sprayed and blew with compressed air until I was sure there was no oil then I took silicone and pushed up into the corners and when I thought I had pushed enough silicone up there I pushed some more. It worked. Now I'd just redo the job with new gaskets. But if you're short on time cause it's a working tractor you might try it.
Jeremy B
04-25-2008 04:19:09
Go to your Allis dealer and get a new gasket set. The Allis kits come with the little clips to help hold the cork gaskets in place. And like the other guys said don't cut the ends of the cork off, and put em in a can overnight to help get em shaped.
Jay W
04-24-2008 15:05:47
Buy the pan gasket kit that has the clips to hold cork in place it will save you alot of headaches. Jay
Kip-Utah
04-24-2008 09:46:13
Mistake shortening the end pieces. It helps if you soak the end pieces in a round container over nite to form them. Better buy a new pan gasket set & start over. Kip
JMS/.MN
04-24-2008 12:09:19
 Re: WD 45 Oil Pan in reply to Kip-Utah, 04-24-2008 09:46:13
Exactly. Probably why it says in the I&T AC-11 manual- do not cut off the cork gasket. If the engine is on a stand, turn the engine upside down, set the warm/wet corks in place and set the pan over them. Great way to shape them overnight.
