WD45 hydraulic pump needed
Burke Hancock
04-23-2008 08:21:26
Wondering if anyone out there has a hydraulic pump for my 56 wd45. How much and shipped to 55803. I am getting no hydraulic movement even after filling with fluid. Thanks
NEKS
04-23-2008 19:17:59
 Re: WD45 hydraulic pump needed in reply to Burke Hancock, 04-23-2008 08:21:26
Had this WD for years and as soon as I put a loader on it the pump quit working. Had metal shavings in valves. Must of come out of the cylinders on the loader.
kendak
04-23-2008 15:44:45
got one I took off a 56 WD-45,,,,,$60 ...shipped....Kent
JMS/.MN
04-23-2008 09:01:42
Have you determined that the pump is at fault? Have you tried setting the four screws per the decal on the battery box, according to what you want to set it for? Might be a valve problem while the pump is still good.
Burke Hancock
04-23-2008 09:58:14
 Re: WD45 hydraulic pump needed in reply to JMS/.MN, 04-23-2008 09:01:42
I have tried calibrating the screws and to no avail. I cant get any pressure in the system. Do you think maybe the valve on top of the pump is blocked or frozen??
JMS/.MN
04-23-2008 15:01:09
 Re: WD45 hydraulic pump needed in reply to Burke Hancock, 04-23-2008 09:58:14
KISS formula- simple things first. Just the other day, on these boards, someone replaced a pump and nothing worked. Friend thought the pump sounded starved for oil. Answer- CLEAN the screen ahead of the pump. Sure, the pump can still be bad, but get the I&T AC-11 manual or the factory shop service manual, take the valve apart and make sure all of that is ok before replacing the pump. Old has a pump, I have an extra, too, but do the simple things first. Diagnosis is at least as important as repair.
old
04-23-2008 11:16:17
I might have a pump. Its on an old WD parts tractor out back. It worked when I use it and another one to make a good tractor. E-mail is open
