electrical
Bob Lafontaine
04-23-2008 05:09:34
When did A.C. switch from + ground to - ground.Just bought a forklift with alternater never heard of a - ground alternater. Any help would appresiated. Thanks, BOB
old
04-23-2008 07:55:16
 Re: electrical in reply to Bob Lafontaine, 04-23-2008 05:09:34
Not sure where you are but 99% of alternators are Negative ground, at least in the U.S.A. Most common one used to switch from 6 volts to 12 volts is the Delco 10si because it is so simple to wire up and cost as little as $25
Kentb of SWMO
04-23-2008 06:23:10
I think the switch from POSITIVE ground to NEGATIVE ground when the switch to ALTERNATORS. We have five C-II Gleaners in the extended family. All were Positive ground. Dad's and little brother's 190,s with a stock Delco alternator are negative ground. All but one of the Gleaners are now negative grd because they have been retrofitted with alternators.
Kent
