D17 head reassembly
Paulinkansas
04-22-2008 11:35:29
D17, gas, series 3. I removed the head and had a valve job done. Now I'm putting it back together. The complete rocker shaft assembly is resting on the head, with 4 threaded bolts sticking out of the head going through the rocker shaft supports. I don't remember what goes on next.
I have the oil splash shield, flat washers, nuts, rubber washers, and the valve cover left. In what order do I reassemble them?
PullingWC
04-22-2008 16:02:51
 Re: D17 head reassembly in reply to Paulinkansas, 04-22-2008 11:35:29
The oil shield, then thighten the rocker shaft down check vavles,vavle cover,rubber washers,flat washers then the last 4 nuts.
Edpap
04-22-2008 20:17:39
 Re: D17 head reassembly in reply to PullingWC, 04-22-2008 16:02:51
Make sure the push rods are in and seated
