need WD-45 hand clutch
RKR
04-21-2008 19:53:20
I need to replace the hand clutch in my WD-45 as it won't hold when pulling hard. No adjustment left. Any sources out there? Thanks.
Michigan Tom
04-22-2008 12:14:44
 Re: need WD-45 hand clutch in reply to RKR, 04-21-2008 19:53:20
Had ours rebuilt about ten years ago. I called around until I found a clutch shop that could obtain Rockford clutch parts. It was expense, but I was satisfied with the results. Do you have all of the shims removed? Also, you can remove the large snap ring and rotate the assembly so the rollers have a new mating surface. This makes a large difference. Tom
mlpankey
04-22-2008 06:07:41
take it out . use a pto gear hub to bolt up the transmission splines .
