WD head gasket
WV Ike
04-20-2008 19:42:18
I just bought a WD that the head was redone on. Put her on my dyno to set the carb and timming. Noticed that the ol girl was seeping oil all the way around the head gasket. I'm looking for an all cooper gasket.Is there anything I should look for when I pull the head that may be an issue? I'm not sure where to go find a gasket at. Thanks for any help.
David Maddux
04-22-2008 05:00:03
 Re: WD head gasket in reply to WV Ike, 04-20-2008 19:42:18
You should probably run it about 15 minutes then retorque the head. Run it for 30 minutes then retorque it again. Then put it on a dyno and I think your gasket will hold. I hasve had the same problem in the past. The main thing is to retorque the first time and not wait too long .
MLPANKEY
04-21-2008 08:09:58
WV Ike said: (quoted from post at 19:42:18 04/20/08) I just bought a WD that the head was redone on. Put her on my dyno to set the carb and timming. Noticed that the ol girl was seeping oil all the way around the head gasket. I'm looking for an all cooper gasket.Is there anything I should look for when I pull the head that may be an issue? I'm not sure where to go find a gasket at. Thanks for any help.
use a felpro gasket you want have any promblems. remember before you can use a copper head gasket you have to oring either the block or the head . barney taylor has copper gaskets for sale.
Jeff Z.
04-21-2008 07:00:57
Search Google for custom made gaskets. They will need an old gasket in good shape. The last quote I got for one custom made copper head gasket was $125.00.
