Advice needed...Rear main seal on a CA
Steve in S. IL
04-17-2008 06:46:34
I think I need to replace the rear main seal on my CA. The book says to remove the engine. Is it necessary to remove the engine, or can the tractor be split, remove the clutch and flywheel, then gain access the seal?
Any advice will be greatly appreciated.
Thanks,
Steve in S. IL
Dick L
04-17-2008 08:19:38
 Re: Advice needed...Rear main seal on a CA in reply to Steve in S. IL, 04-17-2008 06:46:34
Yes! What you said but that is kinda removing the engine. You will have to remove the pan to get a proper seal. Two pan bolts are in the seal retainer.
Thought I had a better picture but didn't run across it.
third party image
Dick L
04-17-2008 08:19:34
third party image
