Three point for a CA
Mike in Ohio
04-16-2008 05:38:00
I built a three point conversion for dad's ca but I do not like the "u" shaped collar that the top link hooks to. I have seen tractors with a bracket welded on to the bar between the lift arms. Have any of you guys done this and can you post some pictures? I mainly want to see the angle you mounted it at. Thanks alot, Mike
JW in NH
04-16-2008 09:29:37
 Re: Three point for a CA in reply to Mike in Ohio, 04-16-2008 05:38:00
Mike,
I bought mine from Valubuilt. The top link goes to the rod between the lift arms: Held in place between two clamps. Works good!! I have land scapping blade and a round bale spear that I use all the time. No Problems. I will try to get you pictures tonight,(Iam on lunch at work) If the snow will let me get to the tractor.
JW in NH
Nat
04-16-2008 17:44:12
 Re: Three point for a CA in reply to JW in NH, 04-16-2008 09:29:37
I welded mine to the rockshaft. No problems so far. Most of the AC guys I know say weld the top link bracket, the loop messes up the floor pan. Later, Nat
