AC B Broken in the field NEED help
IronPony
04-15-2008 11:46:51
was dragging a spring tooth harrow in the field the other day and my b started missing then seem to struggle and shut down like it was locking up. I walked away from it and came back later to start it and since I start by crank it would not go and seen like it does have much compreesion now. open to any and all suggestions
thanks
ed in cny
04-21-2008 09:50:46
 Re: AC B Broken in the field NEED help in reply to IronPony, 04-15-2008 11:46:51
Was it hot when you were doing the work? If so you may have had a vapor lock in the fule line. I have had this happen on one of my B's. If so there is a fix to the problem. It is caused bu the fule line getting hot up next to the block. Try running the line around the air cleaner to the carb and see if that dosn't help.
Don L C
04-18-2008 15:40:47
I guess you checked the gas..... .
mlpankey
04-18-2008 11:15:08
have you checked the oil lately ? awe it doesnt matter just go to the parts house and by a quart of oil and four spark plugs . install new plugs as for the quart of oil it was just so youll have both hands full when you leave the parts house . it also helps the economy
mlpankey
04-18-2008 11:16:29
 Re: AC B Broken in the field NEED help in reply to mlpankey, 04-18-2008 11:15:08
oh yeah i forgot clean out the sediment bowl
Shawn Auman
04-16-2008 17:03:17
Start with the basics
Spark
Fuel- I need a good inches or 2 of gas in the tank for my B for it to run.
chalmersbob
04-15-2008 19:31:38
1. release the hand brakes
2. check the timing
3. check the valve clearance
4. don't ask me how I know.
Bob
Brian Jasper co. Ia
04-15-2008 17:47:58
Are you saying it doesn't have much compression? You might try setting the valve lash. Pretty easy to do. If the valves were set too close, they may not be closing all the way.
Dick L
04-15-2008 11:54:57
I would start by checking spark. If you can crank it over it would not be locked up.
