WD shifter problem
Kevin N.
04-14-2008 18:00:29
My WD is stuck in 3rd gear. There seems to be excessive left/right play in the shift lever but I can"t pull it back at all. Also I can pull the shifter up more than I think I should be able to. Any suggestions?
Will Herring
04-17-2008 14:44:02
 Re: WD shifter problem in reply to Kevin N., 04-14-2008 18:00:29
I've had this happen to me three times, though it was reverse. It was a pain to get it fixed so it finally would not slip out.
John (C-IL)
04-15-2008 04:26:29
You have pulled your shift lever out of the shifting forks groove. Pull up the rubber boot, remove the snap ring and spring washer and pull the shifter out being carefull not to drop the guide key in the side of the tower down into the transmission. Look down in the shift tower hole for the shift forks and line them up with a big screw driver or pry bar. Drop the shift lever back in the hole aligning the end of the shifter with the slot in the shifting forks. Replace the spring washer and the snap ring, slide the rubber boot down and you are back in business.
This is a fairly common problem and is usually related to wear on the shift lever "ball". Many have successfully rebuilt the end of the shift lever to solve the problem. You don't need to remove the shift tower unless you have fork, detent or shift rail problems.
Kevin N.
04-15-2008 15:36:01
 Re: WD shifter problem in reply to John (C-IL), 04-15-2008 04:26:29
Thanks again. Got it done and it works fine.
Kevin N.
04-15-2008 09:13:39
Thanks! I'll try this as soon as I have time.
