wd brakes
Tony S.
04-14-2008 17:21:51
Can the brakes on a wd come out the top?
Tony S.
04-15-2008 13:18:58
 Re: wd brakes in reply to Tony S., 04-14-2008 17:21:51
I guess what I meant is do I have to take the axle housing off?
JMS/.MN
04-15-2008 16:19:14
 Re: wd brakes in reply to Tony S., 04-15-2008 13:18:58
NO- I know that I get beached at for always saying- buy the op and service manuals- what.....$40 for the pair?...but you guys would save a lot of grief if you would simply do that. These are tractors that were designed for most repair jobs to be done by farmers that grew up with horses!
Tony S.
04-15-2008 18:35:15
 Re: wd brakes in reply to JMS/.MN, 04-15-2008 16:19:14
Doesn't cost anything to ask. Just put a clutch in my Case 1294. Repair manual at CIH is $585.
Tony S.
04-14-2008 20:44:25
Any specifics?
JMS/.MN
04-15-2008 09:36:02
 Re: wd brakes in reply to Tony S., 04-14-2008 20:44:25
The only way they come out is through the top. Usual difficulty is getting the 3/4 inch bottom pin out. Usually well rusted. I prefer to drill a 3/4 hole in flat stock, slip it over the pin and weld it in place. Makes a good handle to wiggle with, heat of welding helps loosen. I&T AC-11 manual has the details on brake work.
alliswd45
04-14-2008 19:08:30
yes they can, it just ain't as easy
