AC Bush hog
Bret4207
04-14-2008 15:59:30
I have a 6 foot Allis bush hog. The clutch appears to be a spring loaded metal to metal set up. I'd like to know if it can be adjusted as I kinda over did it the other day and now the clutch seems to be slipping. I have no ID #I can find. It's a wheeled type and built quite heavy.
Bret4207
04-15-2008 15:33:24
 Re: AC Bush hog in reply to Bret4207, 04-14-2008 15:59:30
Thanks Dave. The humps are still there, but I'm not sure how big they were to start with.
Bret4207
04-15-2008 07:30:09
So I tighten those big nuts up on the spring and that should help?
DiyDave
04-15-2008 09:40:33
 Re: AC Bush hog in reply to Bret4207, 04-15-2008 07:30:09
As long as you haven't ground up the meeting surfaces too bad. If you have flattened out the humps, you can re grind them back into better shape, but that requires a complete dis-assembly.
DiyDave
04-15-2008 03:29:41
A-C rattle clutch can be tightened, biggest mistake most people make is to over grease them. This clutch is also used on A-C pull type combines, if that gives you any ideas!
wolfman
04-14-2008 16:57:41
I have one of these AC 6-ft pull type. I wish I could buy a new one just like it. Maybe two. About 20 years ago the slip clutch got over used and I did something to keep it from slipping-jerry rig likely a mistake cause now you have to be ready to shut off throttle or kick it out of PTO. It'll stall the tractor which means it must have a healthy gear box.
