D14 Motor
J Henkle
04-13-2008 12:13:40
Is there a quick way of knowing which ci motor a D14 has? Also what is the 138ci motor rated at hp wise? I see the 149 is about 30-31.
S/N 6281 if that helps.
Thanks, jh
Texas Denny
04-13-2008 17:27:26
 Re: D14 Motor in reply to J Henkle, 04-13-2008 12:13:40
My book says the D-14 only came with the 149 cu in engine. It developed 30.91 hp on the drawbar and 34.08 on the belt pulley.
J Henkle
04-13-2008 18:31:34
 Re: D14 Motor in reply to Texas Denny, 04-13-2008 17:27:26
Thanks Denny, I see my confusion now. I was looking at engine rebuild kits and saw a 138 kit. I'm guessing the same block for several of the smaller D series tractors.
Thanks a ton! jh
Texas Denny
04-13-2008 19:21:31
 Re: D14 Motor in reply to J Henkle, 04-13-2008 18:31:34
Good assumption. The D-10 Series I had a 138.7 cu in displacement. The Series II D-10 had a 149. This was also true for the D-12. I believe the D-15 Series I gas also used the same block. I don't know about the D-15 Series II as the bore was getting pretty big for that block.
