Allis G..Polarizinfg Generator
AWB
04-13-2008 09:07:57
What two terminals am I supposed to temporarily short across to properly polarize a generator? The tractor is equipped with a cut out. Thanks, ahead of time.
AWB
04-13-2008 19:19:23
 Re: Allis G..Polarizinfg Generator in reply to AWB, 04-13-2008 09:07:57
Kentb of SWMO: Thank you for the generator polarizing information.
Kentb of SWMO
04-13-2008 13:10:16
The "G" trminal can also be marked "A". Since you have the cut-out system, you can use a short piece of wire and jumper the two terminals on the cut-out. Boycoot TV coverage of the RED CHINESE Summer Olympics!! Kent
John T
04-13-2008 11:05:03
To add to Joes good remarks, if you DO NOT get a spark when polarizing, there may be a poor or missing ground connection somewhere. It takes current through the field windings to magnetize the pole shoes remember.
John T
AWB
04-13-2008 19:21:31
 Re: Allis G..Polarizinfg Generator in reply to John T, 04-13-2008 11:05:03
John T: Thank you for the generator polarizing information.
Joe M(GA)
04-13-2008 09:30:07
To polarize the generator, simply make a short jumper wire to short between the battery (b or bat) and generator (g or gen) lugs on the cutout relay or voltage regulator. Only a split-second or a spark is required, so simply tap your jumper wire onto the lugs and pull them right back off.
AWB
04-13-2008 19:23:26
 Re: Allis G..Polarizinfg Generator in reply to Joe M(GA), 04-13-2008 09:30:07
JoeM(GA): Thank you for the information on polarizing a generator.
