RalphWD45
04-13-2008 01:24:32
Re: Road saftey lights in reply to RalphWD45, 04-11-2008 20:21:14
Thanks Don, I used your suggestion, and it worked fine. I took the B and wd45 over to the property today, and really needed all the saftey equipment I can find. Those nuts on the road seem to think that you dont belong in their world. I learned real quickly this morning, not to hang over to the right shoulder, but hog the center of the lane. The mounted disc on the B sticks out a couple of feet past the rear tire, so I held over to the right, to keep oncoming traffic from snagging it. The dummies behind me took it as a signal to try to use the center line and pass, It got a little hairy there till I took up the whole lane. My older brother was behind me ,on the WD45, with the mounted plow, and the wife was bringing up the rear, with the truck , useing the Hazzards. We all got educated today. John, that is not a bad idea, to use a jumper battery, however it would be hard to keep aboard either tractor, without making brackets for it. Well Thanks guys for the info, and have a great spring. Ralph
