WD45 brakes
MILLARD HAYES
04-07-2008 19:16:00
Well today we took off the brake covers and discovered the right brake drum had a chunk broke off leaving only half of it. This looks like a real job. I suppose that the brakes want work with only half of it. We dread this.
Texas Denny
04-08-2008 09:07:29
 Re: WD45 brakes in reply to MILLARD HAYES, 04-07-2008 19:16:00
You are correct. This is a tough job.
I believe there is a snap ring on this drum. I can't tell from my manuals which side this snap ring is on but it appears to be the main thing holding on the drum. Even with the ring removed, the book says to use a suitable puller to remove it. Since yours is broken, this offers you some options such as serious heat or even cutting it off. You will need to remove the final drive from that side to get at it.
You may need to remove some of the rear axle gear oil so it doesn't run out the seal and bearing when removing the axle. It is a good idea to replace the seal when you do this. Seals get old and work fine if undisturbed - removing the axle may disturb it enough so that it will leak after assembly.
Jeff Z.
04-08-2008 04:30:24
I know what you mean. We have 8 tractors and it is like having 8 kids. One is always needing something.
