How do you remove a 3 point hitch lift cylinder
Brad Kimmick
04-06-2008 14:00:38
I have a 1979 Allis-Chalmers 185 tractor and I need to remove the 3 point hitch cylinder, but I can't figure out how to get it off. Does anybody have any info on this?
Jr64
04-07-2008 04:32:56
 Re: How do you remove a 3 point hitch lift cylinder in reply to Brad Kimmick, 04-06-2008 14:00:38
I don't own a 185 but as no one else has responded, I'll take a shot at it.
I had the cylinders off of a 190. I ended up dropping the three point all the way down, pulling the cylinder pins out, lift the three point arms, drop the cylinder as much as I could. Then I was able to get at the hydraulic lines to get them loose. I remember everything was a tight fit.
