Brown transmission oil
IndianaTom
04-03-2008 09:25:42
I recently purchased a 175 Diesel with about 2300 hrs. I changed the transmission oil because it was a brown color, not the black I expected. Was this just due to the oil not being changed for too long a period?
kipn
04-03-2008 14:23:39
 Re: Brown transmission oil in reply to IndianaTom, 04-03-2008 09:25:42
Transmision oil turns brown from the clutch plates slipping or burning. black tranny oil would mean beyond repair.
Big Hunter
04-03-2008 14:06:16
I opened up a tractor once and it had 1 inch of dirt goo laying in the bottom. If I were you I would try to stick something into the drain hole and see if you can scoop anything yuck out off the bottom. The stuff that was in mine didn't drain out it was so thick.
CAL (KS)
04-03-2008 10:26:00
transmission oil wont be black. engine oil is black from soot caused by burning diesel. if the oil is milky or foamy then id worry. you now know for sure when it was changed last, and can now maintaiin accordingly.
