TL-12 Tractomotive parts needed
Don Nelson
04-02-2008 21:41:45
Looking for a starter, hydralic pump housing, and rebuildable engine block for a TL-12 gas 226. I would appreciate any leads or responses.
David(MN)
04-03-2008 17:35:32
 Re: TL-12 Tractomotive parts needed in reply to Don Nelson, 04-02-2008 21:41:45
Don, The starter is a delco #1107227, it is off a gas 262 gleamer maybe with the number someone will know if it will fit for sure.
David(MN)
04-03-2008 17:25:30
How do I post a picture on here? Thanks
David(MN)
04-03-2008 09:35:59
Don I have a starter for a 262 gas for sale. In my TL 12 I have a 262 gas engine from gleamer C.
It was a d262 diesel, and changed it, bolts right in, using the orginal disel bell housing.
Don Nelson
04-03-2008 14:44:17
 Re: TL-12 Tractomotive parts needed in reply to David(MN), 04-03-2008 09:35:59
David, How much do you need for your starter if it fits a g226?
Thanks,
Don
CAL (KS)
04-03-2008 07:01:03
Don, my boss has a TL 12 that i have run quite a bit. any WC-WD-45 block will work. WD45 or e gleaner block are sturdier. i think that a starter from a A or C combine with 230-262 gas are similiar. I have an A combine and it looks the same. Im not sure what you mean by pump housing? Bellhousing would have to come from another TL12. Hyd pump housing is solved by buying a new pump to replace.
good luck
Don Nelson
04-03-2008 14:50:20
 Re: TL-12 Tractomotive parts needed in reply to CAL (KS), 04-03-2008 07:01:03
CAL, Do you have any TL-12 parts for sale? Starter, hydralic pump, engine block?
Thanks,
Don
CAL (KS)
04-07-2008 06:32:52
 Re: TL-12 Tractomotive parts needed in reply to Don Nelson, 04-03-2008 14:50:20
im sorry Don, i dont have any parts. I can tell you that the original hyd pump on my boss's loader has been replaced with a newer higher flow unit. if your interested i can try and find some numbers or info on it.
Don Nelson
04-13-2008 20:06:22
 Re: TL-12 Tractomotive parts needed in reply to CAL (KS), 04-07-2008 06:32:52
Kal, Thanks for the reply. I would like info on the newer htdralic pump as we will need to replace it.
Don
Don Nelson
04-18-2008 08:08:17
 Re: TL-12 Tractomotive parts needed in reply to Don Nelson, 04-13-2008 20:06:22
Kal,
Please send info on the new hydralic pump as we will need to replace ours,
Thanks,
Don
