what should i look for
streak
03-31-2008 16:39:52
when looking to buy an allis wd45 for example with internationals its the TA what should i look for with this particular tractor
Garry from SD
04-01-2008 07:23:55
 Re: what should i look for in reply to streak, 03-31-2008 16:39:52
It depends on a couple things. What you want to do with it? And how much are you willing to spend?
In a WD45 if you're looking for rarity and power, go with a diesel. The diesels have a 6 cylinder engine compared to the 4 cylinder gas. They will be more expensive though. Other then that, like what was said earlier, just make sure your getting a 45 motor in a gas tractor. I think LPs are rare too but don't know much about them for comparison against gas.
Clay in MI
04-01-2008 05:23:12
Not too many things beyond the normal tractor stuff like rotted rear rims, smoke, water in oil, etc. The shifter forks wear and can cause them to get stuck in gear. Hydraulic pumps get weak but can be repaired. The biggest thing to look for is make sure it is a WD45! Lots of hybridizing over the years. The transmission should have a curved shifter (I know late WD's had that too) and there should not be a big (7"X20"?)metal plate bolted to the right side of the engine. The WD engine, with less hp and a little less value, has that plate.
