wd 45 headlight conversion
w0oge
03-31-2008 14:09:46
have a wd45,want to convert the head lights to a sealed beam 12 volt, need a bulb number or sealed bulb, had a pair of 6 volt given to me. tractor is changed too 12 volt already, pls forgive me it's not pure but it works for me..
pls help
Brian Jasper co. Ia
04-08-2008 19:32:07
 Re: wd 45 headlight conversion in reply to w0oge, 03-31-2008 14:09:46
A few years back, (about 10) I took a pair of those rubber work lights and cut the backs off them and trimmed them to fit in the original headlight housings. I had intended to do something better later, but later hasn't made it yet. Plus, it doesn't look bad.
w0oge
04-05-2008 16:41:22
thanks for the info, I searched some more and found a site that listed sevral bulbs to try
he suggested with the 1156 and moved up to a
1195 this bulb is the 12 volt version best i can tell of the 1133 6 volt.
1195 is 50 candle power and rate at 36 watts
12 volt ,same base and all will try it to see how long it last
woog
Leroy
04-01-2008 13:45:19
If the orignal lights are not seeled beam they cannot be converted. Just buy a set of standard 12 volt backup light bulbs and put in. If already changed to a seeled beam light just change the bulb, seeled beam.
Gordon in IN
03-31-2008 21:10:11
If you have 6 volt sealed beam bulbs that fit and are good you may want to just install them and wire them in series. I have a WC that has been that way for over 20 years. No reason to buy new stuff if you have good old stuff. Good luck, Gordon in IN
