HELP!! creeping hydraulic system
KEN
11-19-1999 12:22:58
i have a 53 wd. i have a grader blade (2 pt hitch)with a snap coupler hitch. as i use the grader to grade my gravel road and plowing snow. it creeps either up or down. is there a way to stop this? could a person put a shutoff valve in the hyd cylinder lines and when the blade is set at the desired height, close off the flow. the way it is now is useless as i am either digging up gravel or not removing enough snow.
Bo
11-20-1999 05:53:18
 Re: HELP!! creeping hydraulic system in reply to KEN, 11-19-1999 12:22:58
This probably wont help you but I have an AC-B with a single action cylinder; it only provides lifting action when engaged via the pto pump that is not 'live'. It will lift the blade for turning and moving...then drop the blade. I limit the amount of drop with the screw jack that is adjacent to the cylinder and can make adjustment by manually cranking on the jack screw while in the driver seat; I can make small adjustment while moving...not the best but gets the job done.
Regards
Bo
