Allis B three point hitch conversion
Carbonfibers
03-31-2008 07:27:49
Corrected version
I am thinking of converting my Allis B to a three point hitch system to allow me to use a small bush hog. Is there a preferred three point hitch for this application?
Thanks,
Wayne
Mike (MA)
04-03-2008 15:51:16
 Re: Allis B three point hitch conversion in reply to Carbonfibers, 03-31-2008 07:27:49
I installed a three point conversion on my C and have found it to be most useful when running with the engine side weights installed. I had good luck with the kit from Jim Danforth at O K tractor.
Mike
Mark - IN.
03-31-2008 18:13:28
Take a look.
jeffalex2
03-31-2008 15:30:26
Old's right...front is light on a B...you'd do better to get a pull behind 4ft bush hog...
old
03-31-2008 10:20:56
I built one on my C not long ago. I used the plow lift to do so and it seems to work well. I also used cylinders off a WD since they are bigger. Big problem is the front end is light on both the B and C
Jeff Z.
03-31-2008 09:48:05
Give Tony a call at Tony's Tractors. He can set you up.
503-767-3660
