WD45 Rockshaft Bushings
Hossman
03-28-2008 16:03:14
Fellas, On one of my wd45's the rockshaft bushings are shot. I mean to the point of paper thin.There always walkin out on the shaft when raisin an lowerin implements. Couple days back an implement hung up and wouldnt drop when one of the ol bushins wadded up. I ordered new ones and after removin the whole rockshaft assembly found I couldnt get the lift arm off the shaft.Does any one have any experience gettin these dang things off! I took the snapring off the end of shaft and tried beatin the thing with a big brass rod and even bigger hammer,no movement at all. Then tried heatin up the lift arm with rosebud then retried the BFH, still no luck. I dropped the whole deal off at a machine shop to let em try their luck with hydrolic press and afterputtin in the press still wouldnt budge. Now the ol boy didnt put the whole press pressure to bear on it for fear of splittin the collars on the lift arms. Said he would try soakin the thing a while and try again then call if any luck. Well that was two days ago and aint heard from him yet.Was just wonderin if any one had got these off before or not? Thanks for any advice, Hoss
