WD45 misses with no load
Mike in Ohio
03-28-2008 06:41:51
Our Wd45 misses pretty badly when it has no load, when going down hill or even on level ground when not pulling hard. Going uphill or pulling hard it runs great. Going to start tomorrow with the basics, plugs points etc. We use this tractor mostly for mowing. What plugs do you guys recomend? does anybody have any other ideas what might be causing this? Thanks alot, Mike
tractormiallis
03-28-2008 20:54:09
 Re: WD45 misses with no load in reply to Mike in Ohio, 03-28-2008 06:41:51
Most old Allis' like Autolite 295 plugs. Run them in the smaller Allis gas tractors, most AC enthusiasts will tell you the tractors have a liking for those plugs.
Harry J. Case
03-28-2008 20:16:54
Hey Mike One of my WCs acted just like that, ran really choppy, missing and popping without a load but sounded good under a load,found that it had very low compression on three of the four cylinders. Do a compression check if the correct plugs don't fix the problem. Good luck, Harry
Texas Denny
03-28-2008 07:23:57
Mike, a few years ago, I rebuilt a WD with 4 1/8 M&W cylinders. I did a full tune up. When I started the tractor, it missed - it was a random miss - not always the same cylinder. I pulled the manifold and resurfaced it. I rechecked the valve clearance. Still the miss persisted. In frustration, I removed the brand new Champion spark plugs and replaced them with the AC plugs that I'd pulled during rebuild. I fired her up and she ran perfect - never a stutter. Having brand new plugs doesn't guarantee that they are good plugs. I couldn't get those new Champions to work right in anything. It may not be your problem but it is an easy thing to try.
Myself, I use only AC or Autolite plugs.
