Need Magneto Help, 1945 C
got-2-many-tractors
03-24-2008 08:46:04
I bought a 1945 Allis-C. It's got the Fairbanks-Morse FM-J4A magneto. I downloaded the service manual off this site by going through old posts. Here's my trouble. I removed the endcap from the frame of the magneto & filed my points. Now I have a GREAT snappy spark @ the breaker points. Now, I can't "time" the disributor gear to the gear in the cap that sets my timeing. The service manual says that there should be a single marked tooth on my distributor gear...I don't have a single marked tooth. If it was ever marked, it is long faded away. I do have a square keyway that ailigns that gear to the shaft, is one of the teeth on ither side the right tooth to line up the cap with? I'm stumped, I've got the tractor to "pop", so, I must be close, but, I can't get it to run.....I have a real good spark @ the plugs now & it is getting fuel....help please.
Al S
03-27-2008 10:41:00
 Re: Need Magneto Help, 1945 C in reply to got-2-many-tractors, 03-24-2008 08:46:04
Hi, I have had the same problem and found the following to work for me: Looking at the square key way you mention, turn the impluse to place the keyway at near 3 o"clock. Then count up (CCW) four teeth. That should be the marked tooth. I then remark it with a little nail polish (borrowed from my wife, of course). It stays in place quite well. For those that had a beveled tooth marking you can recheck with a magnifing glass and perhaps see the old bevel.
chalmersbob
03-24-2008 19:34:51
remove the # 1 spark plug and get the engine on tdc( when the air comes out of the plug hole) then put the rotor at the # 1 position and put the 2 parts together. that will have you timed. Bob
TIM at nc
03-24-2008 11:03:48
Try this link for timing a mag. I have a B that I ran into the same problem and this is what I used to time it.
Link
stu (ON)
03-24-2008 09:20:49
Here are pics from Duey.
old
03-24-2008 09:03:31
Depending on how its mark the mark can be a little bevel on the gear, a punch mark or a white line which could be rubbed off
