Hey, the old 5020 is running again!!!!
cadet trooper
03-19-2008 16:27:03
Got my AC5020 running tonite, would've got it running last night but make note to self make sure push rods are in the lifter sockets when installing rocker arm assembly. I thought it was turning over too easy and I wasn't getting any smoke except a little out of the exhaust and intake (what?) and fuel coming out of the exhaust drain hole so fixed that problem tonight and the old girl spit out smoke and rust flakes while cranking it over and now I have to clean up black stains every where. Anyway she's good to go and the three point hitch works, all gears are good and pto works along with brakes and etc. Thanks guys for your help and now looking for leaks and making sure no anti freeze doesn't show up in the crankcase since I had to use the old head gasket. Tach has issues with noise and I'm guessing it was setting too long. It has minimal blowby based on the fact it has a new set of chrome rings.
Dick L
03-20-2008 08:40:01
 Re: Hey, the old 5020 is running again!!!! in reply to cadet trooper, 03-19-2008 16:27:03
Fantastic!
cadet trooper
03-20-2008 17:20:06
 Re: Hey, the old 5020 is running again!!!! in reply to Dick L, 03-20-2008 08:40:01
Hey Dick L, while I've got you on here I've got the drive mule for the mid mount mower deck and since the previous owners sent the mower deck off to the scrapper I have no need for it and the toggle switch is trashed and I have no intention of putting one back on with rear ag tires I'm going to use my tractor for landscape work with the 3pt hitch and PTO. But anyway the mule is froze up I'm guessing a bearing issue if you're interested my e-mail is open. We can work something out if you're interested. I just don't have the time to rebuild it and put it on e-bay etc. Let me know. Incidently I had the old girl running tonight started right off ran for two hours absolutely no leaks scrappy little sucker I got on the operators platform with my big feet and hit the accelerator I thought it was going to take off for the moon. CT
