WC 6 bolt rear hubs
jhb
03-17-2008 12:59:40
Where can I find WC 6 bolt rear hubs with or without 38 inch rims? Good rims not a necessity.
I can weld rims on. I am in East Central Iowa.
JMS/.MN
03-17-2008 17:18:33
 Re: WC 6 bolt rear hubs in reply to jhb, 03-17-2008 12:59:40
I think there is a bit of confusion here- hubs, wheel centers, rims Three different things. Hub, six bolt, is the part on the tractor axle. Wheel center, is what bolts onto the hub. The center can be a spoke center with 24 inch rim, used on the unstyled WC, or a cast center that bolts to the hub, and matches to a 28 inch rim.
jhb
03-17-2008 18:07:19
 Re: WC 6 bolt rear hubs in reply to JMS/.MN, 03-17-2008 17:18:33
No confusion. I need the hub and then I will weld my 38 rims on the spokes and go from there. With all the e-mails and calls I have received tonight there is no confusion. Thanks for all the contacts. Keep them coming.
jhb
03-17-2008 18:06:44
R Aiken
03-17-2008 15:38:24
Are you looking for these to make your one wheels?
.third party image
jhb
03-18-2008 02:44:02
 Re: WC 6 bolt rear hubs in reply to R Aiken, 03-17-2008 15:38:24
I need the 6 hole pattern for a WC Allis Chalmers.
Kip-Utah
03-17-2008 15:13:08
38-early 39 WCs used a 24" pressed steel wheel, also F20/F30 Farmall spoke wheels will bolt on & they are 36". Kip
jhb
03-18-2008 02:41:38
 Re: WC 6 bolt rear hubs in reply to Kip-Utah, 03-17-2008 15:13:08
Yes, I need the 6 hole hubs to fit a WC Allis Chalmers. The center hole is about 7 inches. What are the dimensions of this bolt pattern.
Jim Bradley, Dubuque, Iowa 563.590.0721
old
03-17-2008 13:21:53
All the wheel centers I have ever seen on a WC where cast iron and also the rim size for them where 28s not 38s. Or at least all of them I have ever seen where that way
jhb
03-17-2008 14:24:25
 Re: WC 6 bolt rear hubs in reply to old, 03-17-2008 13:21:53
Looking for cut offs or combine hubs with the same 6 bolt pattern.
