Brakes on B
Shawn Auman
03-13-2008 07:30:36
I am replacing the brakes on my B. I pulled the old pads out and found the rivets were rubbing and put some minor groves on the drum. In a car I know how important it is to get them perfectly flat to match the new pads. However I am not going to tear the rear end apart to do it. But I can spin the wheels and put a file on the drum while it turns. My question, is it worth it?
Shawn
jeffalex2
03-15-2008 02:49:06
 Re: Brakes on B in reply to Shawn Auman, 03-13-2008 07:30:36
Yep, like Dick says, you can do it. On a car it's important because small inconsistencies in disc or drum surface can reduce braking effectiveness quite a bit due to the weights and speeds you are dealing with. On a tractor though, especially as small and light as a B, it's not going to have a significant effect.
Dick L
03-19-2008 08:43:04
 Re: Brakes on B Spring problem in reply to Shawn Auman, 03-16-2008 06:17:27
You need the springs. I have changed several from the bolt to the ones like you picture and don't understand the problem. I will go out and look at a couple when I get home tonight. I have a B final drive in the shop with a brake band still on it. I think you might have a hardware problem. Having several tore apart to use for parts I tend to grab what I need to make things work. I do know that I use the same screw that is used for foot brakes and not a bolt or stud when changing styles of brake bands. The factory type brake spring hooks over the head of the factory type adjusting screw.
Dick L
03-13-2008 08:22:24
If you are talking about spinning with the engine I would say that would be setting your self up for a disaster. If you are meaning just rotating the wheel by hand a little at a time as you file I would say yes. I dressed one up several (over 10) years back with a small angle grinder. It was on the tractor I mow with and has worked fine for over 10 years. I have a 4 acre yard which means it gets used a lot.
