WD gearing
Charlie
11-17-1999 11:29:31
How does the WD's gearing compare to the WC? I am going to put a WC motor in an old WD frame but am disapointed in the low speed of the WC. It is way too fast to do some of what I want.How does the WD compare to the old John Deere poppers?
Thanks
tim
11-19-1999 19:00:51
 Re: WD gearing in reply to Charlie, 11-17-1999 11:29:31
yeh the fast ground speed has caused me and some others trouble baling and picking corn with those tractors. some have suggested using smaller diameter tires on the wd to slow it down. however mine needs an overhaul as it is fouling plugs with oil and thinking about talking to a tranny shop that specializes in manual trans and seeing if diffent size gears can be substitued for the ones in there. where there's a will there's a way!!! good luck!
Brian G.
11-18-1999 06:35:33
According to the manuals, the speeds in the WC & the WD with the straight shifter are the same.
