D17 DIESEL STARTER
KENNETH ARMSTEA
03-04-2008 10:54:09
PLESE HELP I HAVE A D17 DIESEL TRACTOR WITH A DELCO 1113082 STARTER ON IT CAN ANY ONE TELL ME IS THERE ANY OTHER STARTER THAT WILL WORK IN ITS PLACE BECAUSE THE ONE I HAVE HAS A BROKEN NOSE CONE SO IT CAN NOT BE REBUILT THANKS
Wisconsin Cowman
03-04-2008 16:17:51
 Re: D17 DIESEL STARTER in reply to KENNETH ARMSTEAD, 03-04-2008 10:54:09
This is the Agco part number for the nose cone 70236345. Your Agco dealer can get you one.
cadet trooper
03-04-2008 14:48:54
If you have a good automotive machine shop not Advanced or the any of the others like that but a NAPA jobber or a good locally owned shop should be able to get the part you need and repair it.
MASSEYMAN178
03-04-2008 13:47:33
if you have the broken off piece a "good" welder could fix it for you.i bought a d15 with the end broken off of the starter because the set screw stripped out and the idiot just let the starter bounce around.had it welded for less than $20
PullingWC
03-04-2008 12:26:13
I think one off of a D19 diesel will also work
