AC Model B 1941 Water in Tranny
Shawn Auman
03-03-2008 05:37:36
Before this tractor was passed down to me my uncle had it stored outside for many years. When I got it found the water mixed with oil in the tranny. The shifter boot was missing for many years. I drained it and let it sit inside with the plugs open 6 months over winter. In spring I filled and ran it for a while. I checked expecting to find nice new oil but found the oil mixed with water again. So how do I get the water out? There appears to be pockets that will not drain.
While I am on the subject, what is the best oil to use? It has a PTO and hydraulic ram.
DARDAN
03-10-2008 23:46:07
 Re: AC Model B 1941 Water in Tranny in reply to Shawn Auman, 03-03-2008 05:37:36
When you drain the rear end again you might want to put the plugs back in the bottom, then fill the transmission/rear end with a couple of gallons of diesel fuel and rock the tractor back to to flush the nasties out. Then drain and flush till clear befor refilling with new oil.
CaseIH has a shift boot #A26956, $10 2 yr ago, that is identical to the original B,C,CA,WC,WD, shift boot. Not the bellows style that AC went to in the '70s.
chalmersbob
03-03-2008 19:08:26
There are a total of 3 plugs to remove.one under the tranny, one under the rear, and one on the pto housing. Bob
Shawn Auman
03-03-2008 09:22:36
Thanks guys. She has been sitting inside for a year or 2. I will get her in the shop this week and drain again. I probably did not do all the plugs last time.
Thanks Again
Ted in NE-OH
03-03-2008 07:08:11
If your tractor has hydraulics, there are three plugs to remove, otherwise two plugs. Also be sure the hyd cyclendar is retracted..
Jeff Z.
03-03-2008 07:18:29
 Re: AC Model B 1941 Water in Tranny in reply to Ted in NE-OH, 03-03-2008 07:08:11
Thanks Ted, I though there were more than two. It's been awhile since I did mine.
Jeff Z.
03-03-2008 06:24:15
If I remember right there may be more drain plugs at the pump. I'm not at the farm this week so I can't look. Get under the rear near the pump with a light and look for plugs. There are oil cavities in this rear.
Jeff Z.
03-03-2008 06:47:24
 Re: AC Model B 1941 Water in Tranny in reply to Jeff Z., 03-03-2008 06:24:15
It's been a long time since I did mine. Trying to remember. The other plugs I think are on the pump besides the one in the bottom of the back of the rear. There is a suction relief valve plug and others by it that can hold some oil.
You also have to remember that the cylinder and line still have bad oil in them.
Jeff Z.
03-03-2008 06:12:26
Use a 20w non-detergent motor oil.
Jeff Z.
03-03-2008 06:08:54
Did you remove the plug in the rear of the tractor under the pump besides the transmission plug?
With both plugs out jack up one side of the tractor and let drain and then jack up the other side.
Jeff Z.
03-03-2008 06:28:24
 Re: AC Model B 1941 Water in Tranny in reply to Jeff Z., 03-03-2008 06:08:54
If you need a new boot give Tony a call.
http://www.tonystractors.com/acec.htm
