185 allis hyd outlets
jd45
03-01-2008 18:50:31
my tractor has hoses that run from the back of the tractor and run up to a metal bracket...that is where u plug in the hydraulic hoses for an implement. the brackets have became bent and my question is can you eliminate this? I have seen some 185's with just a straight outlet comign out of the back of the tractor. thanks for your help.
L.D.W.
03-04-2008 19:13:33
 Re: 185 allis hyd outlets in reply to jd45, 03-01-2008 18:50:31
Yes, you can eliminate them if you want to, and just plumb your outlets directly into the fitting where the hoses currently hook to. But If it was me, I would fix the ones you have now, they are a lot nicer to use!
180doug
03-02-2008 14:02:36
Those are called -breakaway couplers- I think; you have to slide the outer ring in insert hose end and let the outer ring slide back to get proper couple ;early ones come out of the back of the sheet metal piece they are made tight ;it would take alittle sheetmetal +plumbing but it could be done
