Re: WD
Brian
11-17-1999 04:31:50
One of the drawbacks is you can't run to the local farm & fleet store and buy a plow or mounted bush hog unless you convert to a 3 point hitch. You should be able to get these things at farm sales. Just takes a little time to find them. As far as plowing or disking, a WD will run circles around most anything built in its era. The Traction Booster hydraulics are one of the first draft sensitive systems made and they worked much better than just hanging a bunch of weight on the tractor. Like the other guys said, WDs are cheaper than 8,9,2N Fords and there is no comparison when it comes to plowing or disking. Hope this helps, Brian.
