Rewiring connections on CA Allis
DCPULLER
02-27-2008 06:23:18
There was a wire on the bottom of the light switch when I took it appart. Which one is that? The rest I can figure out. Thanks!
Steve in N.J.
03-01-2008 18:57:40
 Re: Rewiring connections on CA Allis in reply to DCPULLER, 02-27-2008 06:23:18
If its the 3 ohm resister terminal you're referring to, that is the field circuit from the "F" (Field) stud on the Generator to the resistor terminal on the 3 pos. switch. That regulates incoming power from the Gennie to the Battery. HTH
Steve@B&B
Dick L
02-27-2008 07:32:36
Trace, ring out the wire/ use multi meter from one end of the wire to the other.
third party image
George R. (MN)
02-27-2008 07:14:02
need to add photo!
George R. (MN)
02-27-2008 07:16:33
 Re: Rewiring connections on CA Allis in reply to George R. (MN), 02-27-2008 07:14:02
third party image
try again!
George R. (MN)
02-27-2008 07:12:35
DC,
If your CA is the original 6V, postive system this should work. If not others on this forum will know more about it. The wire from the "F" terminal on generator goes on the bottom terminal next to the resistor winding on the switch. Go back and check my earlier post with the pic of the ignition box. That may help you. Check photo below of generator for info on "F" terminal.
