b brakes
mawc
02-25-2008 22:36:47
i just put a set of new bands and spring on my footbrake b. i cant adjust the screw out any further to let the levers come up high enough to get the long fender brakets on is this cause they are new or did i do it wrong there is nothing jamed in between the band and the drum either.
jeffalex2
02-27-2008 01:31:45
 Re: b brakes in reply to mawc, 02-25-2008 22:36:47
I had the same problem with my B. Dick and Dave are right, I got them on and working with the old screws and after hitting the brakes a few times, got the adjuster screw about 3/8" into band threads. I wound up grinding down the parking brake cams a little to get them to work though.
Dick L
02-26-2008 07:31:26
The bands tend to not fit tight around the drum when first installed. I just tip the rail up and push the lever thru the opening, push the back down and put the bolts in. You will find that after you drive the tractor and stomp the brakes a few times that you will need to tighten the screw some. You will have to use a prybar to get the brake locks and linkage on. Not to worry it will be fine.
David Maddux
02-26-2008 04:49:23
If I can understand what you are asking, I put new brake bands on a C last winter, and the new adjusting screws were shorter than the old ones. I had to use the old screws.
